Could anyone share with me an example for how to refresh watchdog please ?
1,315 次查看
mohammedaboelna
I need to implement APIs related to watchdog timer.
I could not find any notes or examples on the site.
Could you share please ?
Thanks in advance.
1,229 次查看
mjbcswitzerland
Specialist V
There are different watchdog types in the Kintis parts but this is how the majority of M4 based ones can be retriggered:
    if ((WDOG_STCTRLH & WDOG_STCTRLH_WDOGEN) != 0) {// if watchdog is enabled
        uDisable_Interrupt();                       // protect the refresh sequence from interrupts
            WDOG_REFRESH = WDOG_REFRESH_SEQUENCE_1;
            WDOG_REFRESH = WDOG_REFRESH_SEQUENCE_2;
            WDOG_TMROUTH = 0;
            WDOG_TMROUTL = 0;       // this sequence must be performed within 20 bus cycles (it should be protected against interrupts disturbing it)
        uEnable_Interrupt();
Mark
