Consolidated port control document
1,220 次查看
PatrickD
Hi Everyone, I am currently designing a Kinetis K24 based system. Does anyone know of a consolidated document or section thereof specifying port control and interrupt parameters, e.g. slew rate, drive strength, passive filter characteristics, etc. or must these be gleaned by tediously searching through various sections of the datasheet?
标记 (1)
1,079 次查看
kerryzhou
Hi Patrick Savage-Dickson,
    About the port control and interrupt parameters, please refer to the K24 datasheet, table 11. General switching specifications.
Besides, not all the ports support these feature, you should refer to the reference manual, 10.2.2 Port control and interrupt summary
Wish it helps you!
If you still have question, please contact with me!
Jingjing
1,080 次查看
kerryzhou
Wish it helps you!
Jingjing
