Comparator Input Offset Voltage
1,213件の閲覧回数
admin
Specialist II
I was looking at the comparator specifications for the KL04. The max input offset voltage is set to be 20mV. Where can I find the offset voltage range for the entire temperature operating range?
1,127件の閲覧回数
Paul_Tian
Hi, Goutam
This 20mV offset is the input analog voltage in full temperature range. The offset error will not
Hope my reply can help you.
Best Regards
Paul
