Codewarrior kinetis header file memory map K70FN1M
1,358 次查看
kyuwonjeong
Hi !
I have TWR-K70F120M. So, In order to write a program for the MCU K70FN1M0VMJ12 I need the header file for the MCU. Where can I get the header file and memory map file ?
Thank you in advance.
Kyuwon Jeong
1,283 次查看
kerryzhou
Hi Kyuwon,
    About the K70 header file, please check my attachment.
   About the memory map, you can check the header file, or the K70 reference manual.
Wish it helps you!
Kerry
