CodeWarrior License Questions
tschtj
We use CodeWarrior 10.6 on a legacy product and need to install it on a new P.C.  I'm unable to find an offline CodeWarrior 10.6 offline install and the online install fails (missing download site).
I can find a 10.7 download.  We have permanent floating licenses for 10.6.  Will these continue to work with 10.7 or can someone point me to an offline 10.6 install?
thanks
monika532lara
CodeWarrior 10.6 is no longer hosted, so the online installer fails. Your 10.6 floating licenses generally remain valid for 10.7, but you’ll need to confirm with NXP support since license compatibility can vary by major version. The only way to get an offline 10.6 installer now is through NXP’s support portal or by requesting it directly from their support team, as it isn’t publicly available anymore.
