Code for SPI (Serial peripheral interface) using PCA8561BHN
1,538 次查看
longoal025
Hi,,
Can anyone please post the code for SPI (Serial peripheral interface) using PCA8561BHN
I tried doing display but not work...
Thank you
1,526 次查看
kerryzhou
Hi  longoal025,
   Unfortunately, we don't have the directly PCA8561BHN sample code for your reference, but it is not complicated.
   I don't know which kinetis you are using, you can us the SDK code SPI driver:
https://mcuxpresso.nxp.com/
then you need to refer to PCA8561BHN datasheet, send the related command is OK:
https://www.nxp.com/docs/en/data-sheet/PCA8561.pdf
  You also can search it from the website:
https://bbs.elecfans.com/jishu_949427_1_1.html
It can give you some inclues.
Wish it helps you!
If you still have questions about it, please kindly let me know!
Kerry
