CMSIS --- ??
CMSIS --- ??
2,493件の閲覧回数
eli_hughes
Contributor V
Could someone at Freescale provide a statement as if Codewarrior will ever support CMSIS (Even the Core??)
http://www.arm.com/products/processors/cortex-m/cortex-microcontroller-software-interface-standard.p...
2 返答(返信)
1,835件の閲覧回数
admin
Specialist II
1,835件の閲覧回数
eli_hughes
Contributor V
I have seen the DSP library.   I am more interested in the Core section.  I.e. common access to NVIC, Systick, etc.     This is usually something all of the other Cortex vendors support.   I.E.  when you create a new codewarrior Kinetis Project it should ready ready to go so I can make called to the common CMSIS functions documented on the ARM site.
