CMSIS Library and MCU headers MKL05Z32VLF4
1,819件の閲覧回数
adamvadala-roth
Hi folks
I'm trying to track down the CMSIS library and support headers for the MKL05Z32VLF4 ARM Cortex Mo+ chip. I have a design on its way from the assembler and I would like to get a head start on the firmware. I found the standard CMSIS packages from ARM's official site but I am having trouble locating the files related to my particular Kinetis. Has anyone here used this chip or a similar one without the distributed IDE ? I would like to us Xcode on Mac OS X to build and compile projects for this hardware platform I'm developing and in order to do that I need all the sources and headers but there doesn't seem to be a place where I can find them.
The sample projects for the KL05 Freedom Board have some of the files but I'm not sure I can make use of them without the IDE
FRDM-KL05Z: Freescale Freedom Development Platform for the Kinetis KL05 and KL04 MCUs
タグ(1)
1,503件の閲覧回数
Jorge_Gonzalez
Hello Adam:
In the attached file you will find the necessary CMSIS compliant files specific for your MCU.
Regarding the CMSIS libraries, I recommend you to check the next tutorial by Erich Styger:
Tutorial: Using the ARM CMSIS Library | MCU on Eclipse
That tutorial is for CodeWarrior, but it gives you the idea of how to use the libraries.
Hope this helps!
Regards!,
Jorge Gonzalez
