CAN transceiver
CAN transceiver
vignesh_vb_7
what CAN transceiver is KEA-128 using?
kerryzhou
Hi vignesh balaji,
      TRK-KEA128 is using PC33901 as the High-speed CAN Transceiver, the datasheet of this chip is :
http://cache.freescale.com/files/analog/doc/data_sheet/MC33901.pdf?fpsp=1&WT_TYPE=Data%20Sheets&WT_V...
    For details, please refer to the PC33901 datasheet.
Wish it helps you!
Jingjing
