Bus Fault
Bus Fault
2,616 次查看
PeterFromSweden
This simple program causes a bus fault?!?
int main(void){  uint32_t tmp;  tmp = PORTD_PCR14; // <-- Causes HardFault or BusFault?!?                     // SCB_HFSR = 0x40000000                     // SCB_CFSR = 0x8200   return 0;}
 TWR-K60, Baremetal project.
Any Ideas what happened?
2,297 次查看
Dekiru
You have to enable clock to modules before you access them, otherwise fault will happen.
Example:
/* Enable clock gate to used ports */
 SIM_SCGC5 |= SIM_SCGC5_PORTE_MASK | SIM_SCGC5_PORTB_MASK | SIM_SCGC5_PORTC_MASK;
2,298 次查看
Dekiru
Example:
