Bootloader Problem
Bootloader Problem
mark_bresler
I am continuing to have problems getting my K64f boards to respond as shown in instructional video 3282.  I recently upgraded my laptop to windows 10, and now when I hold the reset switch down as I plug in the cable, the bootloader drive shows for 30 seconds before disappearing. If I rush and drop the  DEBUG-FRDM-K64F_Pemicro_v108a for_OpenSDA_v2.0, I still do not get the mbed driver showing up under Jungo.
I have spent HOURS trying to make this work, and have been concentrating on using my Windows computer for this as my Macintosh seems to have the same problem. Any help would be appreciated, as this is very discouraging.
Mark
jeremyzhou
Hi Mark,
P&E has released a patch for Windows 10 here: http://www.pemicro.com/downloads/download_file.cfm?download_id=460
I've attached a document that explains how to update to this firmware and please refer to it.
Hope it helps.
Ping
jeremyzhou
Hi Mark,
Hope it helps.
Ping
mark_bresler
Thank you Ping for the Window 10 update. I seems to work and download manager now shows the proper items. I will try later to upload a file to the K64F.
Thanks again Mark
