Basic Configuration for I2C on KL27
RicardoRuiz18a
I have been searching in the forum about some examples of how to configure and use i2c but couldn't found any. where i can find some example? Does not matter if is not for KL27, I just want to know how to configure it.
Thank you
Robin_Shen
Hi RicardoRuiz18a,
Please Select Development Board and then Build MCUXpresso SDK v2.9.0 of KL27.
Select Development Board.jpgSelect Development Board.jpgBuild SDK for FRDM-KL27Z.jpgBuild SDK for FRDM-KL27Z.jpg
First you need to install SDK in MCUXpresso IDE, then import examples from SDK.
Here you can refer several I2C example for FRDM-KL27Z.
Robin
bobpaddock
Senior Contributor IV
Repeated Start is broken in parts that have the Double Buffered I2C module such as the KL27.
There are a few discussion about it in the forms.
The SDK gets around the issue by inserting undocumented NOPs to outlast the hardware race condition.
Robin_Shen
Hi RicardoRuiz18a,
Robin
ErichStyger
Specialist I
Hi @RicardoRuiz18a ,
there are examples in the SDK, just use them with the MCUXpresso IDE:
I hope this helps,
Erich
