BSDL file for MK10DN512VMD10
2,963件の閲覧回数
ockertvanschalk
I need the BSDL files for MK10DN512VMD10 (144-ball BGA) and MK10DN512VLQ10 (144-pin QFP). The archive listed under the device's Software & Tools page ("K10_100MHZ_BSDL (REV 0)", Download URL: http://cache.nxp.com/files/microcontrollers/hardware_tools/models/bsdl/K10_100MHZ_BSDL.zip ) only contains the BSDL file for the 121-pin version.
Thanks, regards
Ockie
5 返答(返信)
2,620件の閲覧回数
ivadorazinova
Hi Ockert.
These files are requested on page Kinetis CAD Schematics, Symbols & Footprints|NXP
but currently there is an error on our side, I have reproduced the problem, I will let you know as soon as possible.
Thank you for your patience,
Iva
2,620件の閲覧回数
ockertvanschalk
Hi Iva
Thank you for the response, I look forward to hearing from you.
Ockie
2,619件の閲覧回数
vicentegomez
Hi Ockie
Please check the attached file.
I hope this will help you
2,619件の閲覧回数
ockertvanschalk
Hi Pedro
Thank you for supplying the BSDL file. However, it does not seem to have a valid IDCODE for my specific device, MK10DN512VMD10 (we are using both the 144MAPBGA and 144LQFP variants).
I am using the XJTAG XJLink device to connect to the processor, which reports the following:
____________________________________________________
Starting Check Chain...
1 Devices found
ID Codes read:
0x4BA00477
Chain intact - No errors found
IR length of chain: 4
Device 1 (No BSDL File)
Read : 01001011101000000000010001110111 (0x4BA00477)
If I now supply your BSDL file (K10_144BGA_13x13.bsdl) to the software, I get the following error:
Can you explain why the device reports a different ID Code from that specified in the BSDL file?
Thanks, regards
2,619件の閲覧回数
vicentegomez
Please give me some time to get the update file
Vicente Gomez
