Arm_sqrt_q31 on a Kinetis K MCU
1,874件の閲覧回数
paljano
Hello guys,
I have a very big Problem. I have to implement the arm_sqrt_q31 on my MCU and I cant find any usefull example how I can use it. I wasted a whole day for trying to implement it succuessfull. Is here anyone who can give an example how I can use that function for getting the square root of 144 or another easy number?
Here is one of my tries:
#include "arm_math.h"
int main(void)
    uint32_t n;
    arm_status status;
    status=ARM_MATH_SUCCESS;
    int32_t    temp4    =    0;
    float temp5        =    0;
    arm_sqrt_q31(144,&temp4);
    arm_q31_to_float(&temp4,&temp5,1);
1,523件の閲覧回数
Kan_Li
Hi Eric,
Seem you used this function correctly. what is the issue you met?
Kan
