An example on I2S on FRDM k28 Board
Ajuba
I couldn't find any examples on FLEXIO I2S component under SDK_2.x_FRDM-K28F.
Request to provide the same on FRDM-K28 board and how to use it.
Ajay
_Leo_
That's right, there is no FLEXIO I2S example for the frdmk28f, however you can use the peripherals tool in Config Tool to configure the I2S.
Also you may refer to the I2S demo from other SDKs, like twrk81f150m or twrk80f150m. The FLEXIO modules must be similar or the same, so be aware of the differences.
I share the following link to get some guidance on how to do the demo with another board.
https://community.nxp.com/t5/Kinetis-Microcontrollers/FRDM-KL43Z-FlexIO-I2S-Interrupt-Tx-Demo-with-M...
Do not hesitate to contact me if you need more information.
