About the default Interrupt Prioriy of KE06 MCU
1,029 次查看
freei
Where can I find the default interrupt priority of Ke06 MCU ? If I don't change the defalut mode,IRQ12 's priority is higher than IRQ17?
Can I Set IRQ17's priority higher than IRQ12 by setting the NVICIPR4 register?
Thanks!
901 次查看
pavel_krenek
default priority of all interrupts on KE06 (ARM cortex M0+ core) are 0, that means the highest possible priority. If you would like to change the priority to higher for IRQ17 you have to change all other used interrupts to lower value that for IRQ17.
Pavel
