About the FRDM-k66 flash lock
2,681 次查看
leoq
I meet the problem ,how to do ?
Please give me some help
6 回复数
2,467 次查看
davicampos_le
Do you have any success in unlocking the kinetis?
I'm having the same problem.
2,467 次查看
kerryzhou
Hi Davi Campos,
   Please create a new post and give us the details for your question.
   Your own board or the official board, what the debug your are using.
   We will help you in your new post.
Kerry
2,467 次查看
kerryzhou
Hi qiuhua,
    Please change your FRDM-K66 board 's debugger firmware to JLINK, and also install the jlink driver.
    Then use the JLINK commander window, and input: unlock kinetis
     If you still can't erased, your chip is really secured to the highest level, it can't be secured again.
Please try it at first.
Kerry
2,467 次查看
leoq
First of all , Thank you for your answers.
I don't know the level of secured,and if use the Jlink commander input: unlock kinetis,then display Timeout:QQ截图20170121162513.png
2,467 次查看
kerryzhou
Hi qiuhua li,
  Please in theJLINK commander, input:
mem 0x400, 0x10
  Then give me the output data.
Kerry
2,467 次查看
kerryzhou
Hi Qiuhua li,
     Your chip flash is protected, and you even disabled the mass erase, I don't know whether you also secure the chip.
    If you secure the chip, also disable the mass erase bit, and your chip is secured, then your chip is in the highest secured level III. it will can't be unsecured any more.
    About the secure, please refer to this document:
Kinetis Lock issue analysis and unlock way.pdf
Wish it helps you!
Kerry
