About KL02Z UART Polling Method , Receive Error
3,355 次查看
ellenlin
Dear NXP ,
   I use KL02Z try to make a project with UART ( Polling method ) , IDE is code warrior 11.0 . Baud Rate is almost 9600
   UART Sending data is normal . But Receive Data won't work , has already check PC UART Tool and waveform are normal .
   Attachment is my code , could you help to point out what is wrong with this code ? thanks a lot !!
   void UART_INIT(void)
UART0_C2 &= ~(UART0_C2_TE_MASK | UART0_C2_RE_MASK);
UART0_BDH = 0x01 ;
UART0_BDL = 0x38 ;
UART0_C4 = 0x0F ;
UART0_C1 = 0x00 ;
UART0_C3 = 0x00 ;
UART0_MA1 = 0x00 ;
UART0_S1 |= 0x1F ;
UART0_S2 |= 0xC0 ;
UART0_C2 |= UART0_C2_TE_MASK | UART0_C2_RE_MASK ;
while(1)
while(!(UART0_S1&UART0_S1_RDRF_MASK));     <------------ always wait here
String = UART0_D;
while(!(UART0_S1&UART0_S1_TDRE_MASK)&&!(UART0_S1&UART0_S1_TC_MASK));
UART0_D = String ;
B.R
Ellen Lin
3,279 次查看
jingpan
Hi Lin,
I run your code on my FRDM-KL02. It works fine. Would you please check hardware again?
Jing
3,280 次查看
jingpan
Hi Lin,
Jing
3,279 次查看
ellenlin
Dear Jing Pan &#21729;&#24037; ,
   Thanks for your help , i has already check HW , my connector has some damage so doesn't receive any data , thanks a lot !!
