AN2295 and KV5x?
2,100件の閲覧回数
lsrbigfoot
I have been using AN2295 serial bootloader extensively on K22 MCUs and was wandering if AN2295 serial bootloader also can be used on KV5x series MCUs? (namely MKV58F1M0xxx24)
What changes (Win SW and FW) are required for AN2295 to support usage on MKV58F1M0xxx24?
タグ(3)
2,095件の閲覧回数
Robin_Shen
MCU-Boot is recommend for new design, you can get it from https://mcuxpresso.nxp.com/en/select
bootloader_examples can be found in the latest SDK_2_8_0_MKV58F1M0xxx24.
Documentations about MCU-Boot can be found here:
Robin
2,096件の閲覧回数
Robin_Shen
Robin
2,086件の閲覧回数
lsrbigfoot
Understood. Is MCU-Boot backwards compatible with AN2995 API? Can I use MCU Boot Software to program a device with AN2995 Boot Loader programmed into MCU?
