A question for the MK60F15.h
1,497 次查看
AaronsCook
HI,
Recently,I compare the MK60DZ10.h and the MK60F15.h.I find there is an error in the MK60F15.h in which the SIM_SCGC4_IIC0_MASK is defiened to the SIM_SCGC4_IIC2_MASK. I Search for the datasheet(K60P144M150SF3RM) but not find the IIC2. I think it need to modify.what's more The IIC is defined as SIM_SCGC4_I2C0_MASK in the MK60DZ10.h and SIM_SCGC4_IIC0_MASK in the MK60F15.h.Why don't define as the same name that is convenient to transplant. A little advice for the K60.thank you.:smileyhappy:
标记 (2)
1,367 次查看
Monica
Senior Contributor III
Laplenden,
Your feedback is extremely important.
Thank you very much, we will be reviewing this as soon as possible!
Best regards!
Monica
1,368 次查看
Monica
Laplenden,
Best regards!
Monica
