3D STEP model on Dev boards?
4,000件の閲覧回数
mr_p
Where can a 3D STEP model on the FRDM-K64F development board be found? :smileyconfused:
/Regards, Mr_P
タグ(3)
4 返答(返信)
3,015件の閲覧回数
danielfredricks
Hi Peter - I recently posted the same question, looking for a STEP model of the FRDM-K64F. Did you ever find or create one? If so, would you be willing to share it?  I could create one from the PCB design files NXP makes available but the format is not compatible with my board software.
3,015件の閲覧回数
Hui_Ma
FRDM-K64F board hardware design resource could be downloaded from below link:
http://cache.freescale.com/files/soft_dev_tools/hardware_tools/printed_circuit_boards/bom/FRDM-K64F....
Freescale Freedom Development Platform for Ki|Freescale
Wish it helps.
best regards
Ma Hui
3,015件の閲覧回数
mr_p
Thanks for your reply. I've found thouse files already, but they don't contain any mechanical 3D files of any kind.
The reason for me looking for the mechanical STEP files is that it will help me with the design of an ad-on board
as well as making the mechanical box where all should fit. In my case I'm using Altium electronic designer that
support import of STEP models. Makes life sooooo much easier, and everything get right the first time :smileywink:
I'm hoping that I will not have to do the requested files myself (since it will take a couple of hours to find STEP
on all connectors etc...)
/Regards
3,015件の閲覧回数
Hui_Ma
Hi Peter,
I had tried to find FRDM-K64F board 3D model file inner, unfortunately, there is no related file.
Sorry for that may bring any inconvenience.
Wish it helps.
best regards
Ma Hui
