twr-k64f120 + twr+lcd
1,339 次查看
lorismichielutt
I'm trying to import the library d4d eGUI.
the compilation is correct.
the program seems to run properly.
the twr-LCD is configured correctly.
I eliminated any hardware conflict.
remains a problem only on pin pcr10, there seems to be a conflict on the twr-k64f120.
I think the problem is hardware.
there is' someone who has tried to do the same port?
any ideas or suggestions ?
Thank you and regards.
Loris
Original Attachment has been moved to: prj_twrk64f_ledGYOB_tim1_lcd.zip
标记 (1)
1,264 次查看
lorismichielutt
ok
i solved the problem hardware, now it all works.
