Hello,how can I build the project with command line method KDS. Just like create a makefile to do the compiling. Who can give me an example and guide to do it.
Thanks a lot!
Shaowei
Solved! Go to Solution.
Hello Shaowei Su:
Maybe the next good article by colleague Erich Styger is what you are looking for:
Building Projects with Eclipse from the Command Line | MCU on Eclipse
Regards!
Jorge Gonzalez
Hi Jorge Gonzalez,
Thank you very much!
Shaowei Su
