float printing error in PE
7,005 次查看
syedidris
Hi ,
We are working on KL03 processor (with KDS 3.0.0). We learnt how to make processor expert code and just trying to make simple hello_world printing code. Its working fine but float value is not printing so we change the properties of code as per screenshot, then it is showing some errors,
Our project code is as per the attachment.
Please guide how to print float value in PE code.
Original Attachment has been moved to: print.zip
6,695 次查看
ZhangJennie
David's demo is great. just for supplement, with PE+KSDK, to print floating number,  make sure to have floating enabled in preprocessor.
Jennie Zhang
8 回复数
6,695 次查看
syedidris
Thanks to DavidS​ and ZhangJennie
Now its working,:smileyhappy:
6,695 次查看
syedidris
DavidS​ plz, can you suggest any solution?
6,696 次查看
ZhangJennie
Jennie Zhang
6,696 次查看
DavidS
Hi Syed,
Something was not right with your project and I couldn't easily get it working and am short on time.
Attached is my FRDM-KL03 KDS_3.0+KSDK_1.3+PE and setup to do floating point.
Please review the project Properties and code to how I have it working.
David
6,696 次查看
ZhangJennie
I ever made video of how to how to use printf to print floating value in KDS3.0
see attached.
can this help you?
Jennie Zhang
6,696 次查看
syedidris
Zhang,
we tried your method but still It's giving the error.
6,696 次查看
Hello syed,
To use printf() with floating point, the option "-u _printf_float" needs to be added to the linker options,
about the detail information please refer to here :
printf() and scanf() with GNU ARM Libraries | MCU on Eclipse
Hope it helps
Alice
6,696 次查看
syedidris
Hi Alice,
thanks for your reply.
I added "-u _printf_float" in properties of our project, but it's not working as you can see in my project code.
