failed to unsecure Kinetis device
冷夜王
Hello all,
     I used the chip is MK11DN512VLK5 , and found always appear the Jlink not found the chip .
    This is found the chip is can't used command to erase , can't  used command to unlock Kinetis . And now I was can't programming this chip .
    So I want to know how to make the chip back to normal ? Thanks for your help.
冷夜王
Forget to say I used the JLink driver is SEGGER JLINK 6.12a
Hi 冷夜,
It seems failed to connect board with JLINK.
I recommend you ask to the SEEGER company support :
Main Page - SEGGER Forum
Alice
冷夜王
Hi Alice,
    I connect other board is ok ,is no problem . Only some MK11DN512VLK5 have this problem .
