debug Cortex-M4F floatpoint
6,634件の閲覧回数
q7Nhaj
I experienced the following failed assertion when debugging Cortex-M4F code using floating point.
GCC-4-8-build/src/gdb/gdb/regcache.c:178: internal-error:
register_size: Assertion `regnum >= 0 && regnum <
(gdbarch_num_regs (gdbarch) + gdbarch_num_pseudo_regs (gdbarch))' failed.
All routine that pass a floating point value to the routine will failed when I set a breakpoint inside the routine. GDB crashes as soon as the break is encountered.
Kinetis Design Studio Version: 3.1.0
Eclipse Version: Luna SR2 (4.4.2)
5,516件の閲覧回数
DavidS
Hi Dan,
I heard back from PEMicro and fix should be next week.  Exact wording:
We will post a new release of our GDB server mid-next week to our update site which has this fix.
David
24 返答(返信)
420件の閲覧回数
q7Nhaj
This is the compiler setting that I'm using,
Jim
7:29:35 **** Incremental Build of configuration Debug for project TEST****
make -j8 all
Building file: ../Source/main/TEST.c
Invoking: Cross ARM C Compiler
arm-none-eabi-gcc -mcpu=cortex-m4 -mthumb -mthumb-interwork -mfloat-abi=hard
-mfpu=fpv4-sp-d16 -Og -fmessage-length=0 -fsigned-char -ffunction-sections
-fdata-sections -fsingle-precision-constant -Wunused -Wuninitialized
-Wmissing-declarations -Wlogical-op -Waggregate-return  -g3 -nostdinc
-D_AEABI_LC_CTYPE=C -D__STRICT_ANSI__=1 -D_DEBUG=1
-std=gnu11 -Wmissing-prototypes -Wstrict-prototypes
-fno-strict-aliasing -fms-extensions -finline-functions
-MMD -MP -MF"Source/main/BlackBox.d" -MT"Source/main/BlackBox.o"
-c -o "Source/main/TEST.o" "../Source/main/TEST.c"
Finished building: ../Source/main/TEST.c
Building target: MYCODE.elf
Invoking: Cross ARM C Linker
-mfloat-abi=hard -mfpu=fpv4-sp-d16 -Og -fmessage-length=0
-fsigned-char -ffunction-sections -fdata-sections
-g3 -T
-nostartfiles -nodefaultlibs -Xlinker --gc-sections
-Wl,-Map,"BlackBox.map" --specs=nano.specs -u _printf_float
-u _scanf_float -Xlinker -static  -Xlinker -z -Xlinker muldefs
-o "BlackBox.elf" -Xlinker --start-group
-Xlinker --end-group
Finished building target: MYCODE.elf
420件の閲覧回数
@Hello JIM,
I create one KSDK+PE project about k22 , print the float data to terminal of PC,
it can work well . About the project please see the attachment .
We need define the "PRINTF_FLOAT_ENABLE" macro at the properties:
Hope it hleps
Alice
420件の閲覧回数
q7Nhaj
I download Version v3.2.0 and get the same error.
The debugger will crash by setting a breakpoint in a subroutine that has a float value pass to the routine on the stack.
When the break is encountered the debugger crashes with "GCC-4-8-build/src/gdb/gdb/regcache.c:178: internal-error:
register_size: Assertion `regnum >= 0 && regnum < (gdbarch_num_regs (gdbarch) + gdbarch_num_pseudo_regs (gdbarch))' failed."
in the console window. I was using CodeWarrior 10.3 and the same code work fine for me.
Also the register viewing window in KDS dose not show any of the FPU register.
Jim
420件の閲覧回数
Hello JIM,
Please update the KDS to  KDS v3.2.0 to have a try , about the update steps, please refer to :
New Kinetis Design Studio v3.2.0 available
If still have this error , could you please tell me step by step how to reproduce this error .
Hope it hleps
Alice
