When  flash in KDS2.0.0 , it error
2,187 次查看
Fan_xy
Hello
When flash on KDS2.0.0, TWR-K60D100M board,
I click this :
while , it show :
Where am i wrong ?
And when debug ,it can work well .
Thank
4 回复数
1,967 次查看
ivadorazinova
Hi fan xy,
do not you want to attach the screenshots? Or more specify it?
Iva
1,967 次查看
Fan_xy
Hi Iva,
Thank for your remainder !
I click this :
while , it show :
Where am i wrong ?
Attachment is my project !
Thank you very much !
fan@
1,967 次查看
ivadorazinova
Hi fan xy,
it could cause incorrect settings.
Please, check your flash settings.
I hope it helps you.
Iva
1,967 次查看
davidsherman
Senior Contributor I
It appears it programmed and verified correctly, which is what you would expect if you are trying to flash it.  Looks like it's just reporting that it disconnected after programming and verifying correctly, so what is the error?
