What files for version control?
2,390件の閲覧回数
davepfaltzgraff
Senior Contributor I
I am using KSD with PE and MQX. As I understand it, the MQX functionality is covered by libraries outside of my code. Also, some of the code in my project is generated by PE. So, what is the minimum set of files that I need to submit to version control? (Note: It's also a means of backup and recovery.)
2,203件の閲覧回数
BlackNight
The article Version Control with Processor Expert Projects | MCU on Eclipse is for CodeWarrior, but it applies 98% for Kinetis Design Studio too.
Erich
2,203件の閲覧回数
BlackNight
Erich
2,203件の閲覧回数
davepfaltzgraff
Hi Erich,
That should give me enough to go on
Thanks.
