SPIMaster_LDD Clock Rate Index error on initial project open
2,607 次查看
mattgeerts
Every time that I freshly open a project that contains a SPIMaster_LDD, PE indicates an error in the settings. The error is on the clock rate index = 1 for the high speed clock used by SD card.
After I generate the code the error is cleared.
Is it something that I've done, or a bug in PE error checking? It appears that it doesn't recognize that I've specified a list of clocks in the "Clock rate" dialog.
标记 (2)
2,478 次查看
TICS_Fiona
Hello Matt
I reproduced the problem on my side. It should be a problem of PE. I have reported it to our developers as issue 47617830, and will reply you here for any progress on it.
Fiona Kuang
Technical Information & Commercial Support
2,478 次查看
mattgeerts
Thank you Fiona!
