S-record output
S-record output
davidsherman
Senior Contributor I
I can't find a setting in KDS which was present in CodeWarrior.  I'm trying to generate S-record output.  More specifically, I have regions of ROM that are full of constants that will be stored in an external EEPROM to save flash space.  In older versions of CodeWarrior, there was a way to have the linker export regions to a zero-based S-record file which could be programmed into an EEPROM.
BlackNight
BlackNight
davidsherman
Ah, I missed the checkbox for enabling the flash file output.  Thanks!
