Re: DAC not working on FRDM-K22F ver 2
2,050件の閲覧回数
julioruzicki
HI guys, I'm also having troubles to make the DAC works. I tried your previuos tips but unsuccessfully. I'm using kinetisstudio 3.0.2 and k22f.
Could you help me?
3 返答(返信)
1,938件の閲覧回数
DavidS
Hi Julio,
I dug up the old example I had and configured it to do simple ramping of DAC0_OUT to J24 pin 11 of FRDM-K22F using the KDS3.0.2+PE.
Hope it helps.
David
1,938件の閲覧回数
julioruzicki
Hi David, thanks by your attention. Your code is working but I don't know why, because is similar like examples.
I'll install de version 3.2.0 linux and verify. Some weeks ago I had a similar problem with USB stack but I could solve.
Thank you again.
1,938件の閲覧回数
DavidS
Hi Julio,
Glad to help.
If question answered please mark it correct.
David
