Processor Expert Problem / Generator: FAILURE
3,588件の閲覧回数
walter_gallegos
Hi community !
Someone fall into this FAILURE ?
Generator: ERROR: Code generation canceled by the user    L2I-WIP        Code Generator    Processor Expert Problem
Generator: FAILURE: Unexpected status of script: Drivers\Common\Header.C, please contact Freescale support.    L2I-WIP        MODI2C    Processor Expert Problem
Obviously, I cancellated the code generation. The ERROR report is unexpected also, an info report will be more appropriate, but my question is about de FAILURE report.
saludos
Walter
タグ(1)
4 返答(返信)
3,314件の閲覧回数
walter_gallegos
Hello Alice,
This not a big problem, a simple workaround can solve it but the message "Generator: FAILURE: Unexpected status of script: Drivers\Common\Header.C, please contact Freescale support." is an indisputable indication that the tool is falling into an "Unexpected status".
To reproduce the situation, cancel the Processor Expert code generation in the middle of process. Unfortunately this forum don't accept .mp4 for video screen captures.
Saludos
Walter
3,314件の閲覧回数
Hello Walter,
On the configuration view of your PE component , does it have error ?
Before generate code ,we need configure the component without any error .
And you can tell me the KDS version , send your project to me , i will check it on my side .
Hope it helps
Alice
3,314件の閲覧回数
walter_gallegos
Hello Alice,
We are using KDS 3.2.0, sorry I can't send the project to you.
"Before generate code ,we need configure the component without any error .", obviously.
Pay attention to "Unexpected status of script: Drivers\Common\Header.C, please contact Freescale support. " ?
"Unexpected status..." smells as a bug trapper.
Can you explain this report ?
Walter.
3,314件の閲覧回数
Hello Walter,
How can i reproduce your error ?
It hardly solve the problem only refer to the error report .
Alice
