Processor Expert Components
jamesosborne
HI,
I just started working with Kinetis and Processor Expert. I was able to import projects and can see the selected components in Processor Expert. Some components are grayed out and there are messages in the console window:
Loading RU3APP project components - component "FreeRTOS UUID: version:01.402" was not found/selected from any repository!
Loading RU3APP project components - component "Utility UUID: version:01.106" was not found/selected from any repository!
Loading RU3APP project components - component "Shell UUID: version:01.065" was not found/selected from any repository!
Loading RU3APP project components - component "Wait UUID: version:01.067" was not found/selected from any repository!
Loading RU3APP project components - component "USB_HOST_STACK UUID: version:01.027" was not found/selected from any repository!
Loading RU3APP project components - component "USB_DEVICE_STACK UUID: version:01.027" was not found/selected from any repository!
Can anyone please tell what this means and where to get the correct components?
Thanks, James Osborne
Carlos_Mendoza
Hi James,
Those seem to be McuOnEclipse Processor Expert components, make sure you have already installed them.
Take a look to Erich's response on the following post it mentions where to download them and how to install them:
FreeRTOS on KDS processor Expert
Hope it helps!
Carlos Mendoza
Technical Support Engineer
BlackNight
Hi James,
here is the information about how to get the components:
McuOnEclipse Releases on SourceForge
I hope this helps,
Erich
jamesosborne
Thanks, I did that. I was hoping though there would be a way to get individual components. Those zip files have many components and they all get loaded when installed. Some have different versions from components already installed and it causes warnings.
