Porting a Project from CodeWarrior to KDS IDE
vigneshbalaji
Senior Contributor I
     I want to port a project from CodeWarrior to KDS IDE.I followed the  Documentation but how should i change the codeWarrior dependent libraries permanently?
I want a clear Explanation for What are CodeWarrior dependent libraries in a project and how to change them permanently if we want to export it to KDS? Please Give me a detailed and clear Explanation
ZhangJennie
there is CW to KDS porting guide under C:\Freescale\KDS_3.0.0\doc\pdf\kds_porting_guide.pdf
I will attached it to this thread for your convenience.
Erich ever posted a useful document about  "Comparing CodeWarrior with Kinetis Design Studio". I think it could be also useful to you.
Comparing CodeWarrior with Kinetis Design Studio | MCU on Eclipse
Jennie Zhang
vigneshbalaji
Hi Zhang,
                Will this porting guide be useful for KDS3.2 also???
ZhangJennie
Hi Vignesh,
yes, It will.
If you have KDS3.2 installed, you will find the same version KDS_Porting_Guide.pdf under KDS3.2 install folder:
Jennie Zhang
