OM13260 replacement board
ソリューションへジャンプ
4,571件の閲覧回数
marceli1
I would like to use efficient NXP Fm program for testing PCAL6524 build boards. What is replacement for use USB to I2C interface OM13260 board, which not more manufactured. Can I connect FRDM-MKL25Z demo board to the NXP Fm program?
Marceli
4,447件の閲覧回数
Hui_Ma
Please check and order OM13320, which includes OM13260 in package:
Wish it helps.
best regards,
Mike
3 返答(返信)
4,447件の閲覧回数
marceli1
Thank you I bought OM13320 kit using as production tester with connected mine board to one of I2C bus. It allows me to learn fast code functions. Additionally I made on USB Serial brief corresponding software for mine Expander board.image.png
I am masking pin 0.0 which is connected debounce oscillator to not interfere with readings. Does masking outputs 0x56 will disable usage them?
Marceli
4,448件の閲覧回数
Hui_Ma
Hi Marceli,
To be honest, I don't support analog product, such as PCAL6524 product. I have no idea about the issue.
I would recommend to submit an online support, our analog product engineer can support this issue.
Thanks for understanding.
How to submit a new question for NXP Support
https://community.nxp.com/docs/DOC-329745
best regards,
Mike
4,448件の閲覧回数
Hui_Ma
Wish it helps.
best regards,
Mike
