OLED interfacing with Kinetis
1,373件の閲覧回数
syed_idris
Hi all,
How to display any data (like "Hello" or sensor's data) on the I2C based 132x64 OLED with Kinetis FRDMKL03 ?
Do we have any sample code for it or any PE library component in KDS?
Idris
タグ(3)
1,121件の閲覧回数
jorge_a_vazquez
Hi syed idris
In this case it depends in your 132x64 OLED Specifications but I recommend you to check the example codes of KSDK package software, you can download it here: Software Development Kit for Kinetis MCUs|NXP
There are I2C drivers for KL03 that you could check and add to your project as you need.
If you want to use Processor Expert components you will have to install SDK v1.3, because FRDM-KL03 it's just supported by PE with SDK v1.3.
Hope this information helps and please don't hesitate to ask if you have more questions.
Jorge Alcala
