MQX aware debugging in KDS
1,427 次查看
randyhermes
I am using KDS 3.0 with SDK 1.2.  I have installed the MQX plug-in.
Unfortunately none of the MQX specific debug commands seem to work.
For example when I select MQX/task list - it returns "Task list not retrieved successfully"
I am running on a TWR-K21F120m board using the PNE embedded connection.
I compiled the MQX librbaries for the TWR-K21f120m library without modifications.
What do I need to do to get the MQX aware debugging working?
Randy
1,276 次查看
randyhermes
Hi Alice,
I'm using MQX under SDK 1.2.
I found the problem.  I was trying to retrieve the MQX items too early in the run.
If I set a breakpoint in a task then it works fine.
Thanks for the Response.
Randy
1,276 次查看
Hello Randy,
Have you use the MQX under KSDK 1.2 or individual MQX ?
Please screenshot tell us how do you use the task list,  it is better step by step , i will test it on my side .
Alice
1,277 次查看
randyhermes
Hi Alice,
Randy
