Kinetis Design Studuo Debugger
lstrattan
Hi Team,
Using KDS, when I setup flash from file, and get to debugger section, selecting USB Multilink, USB Multilink FX, Embedded OSBDM/OSJTAG as my interface, and click refresh, the USB Port does not come up.
DebuggerDebugger
When I check Device manager, this is what i receive:
Below is the Programmer I'm using.
Please advise.
Thanks.
Lem
ZhangJennie
HI lstrattan,
Your second picture shows the device not correctly recognized.
Please download USB Multilink Resources Install from this url
https://www.pemicro.com/products/product_viewDetails.cfm?product_id=15320180&productTab=1000000.
This package contains PEFirmwareConfig.exe utility, technical summaries, up-to-date firmware, and other resources.
Using this tool to update P&E multilink FX firmware and install the up-to-date firmware. See how it works.
I would also suggest you chanage another PC can USB cable to isolate influence of other possiable factors
Jun Zhang
