Kinetics design studio project opening problem.
15,349件の閲覧回数
akshaybhavsar
I have installed kinetis Design studio.I have firmware for MK64FN1MOVLL12 controller.I cant open this project as i go to project ->open project.
12 返答(返信)
14,995件の閲覧回数
akshaybhavsar
For 32 bit ubuntu
14,995件の閲覧回数
akshaybhavsar
So,which IDE I can use for MK64FN family controller
Akshay.
14,995件の閲覧回数
sanketmeher
In dont find set up for 32 bit ubuntu OS.I could install it on 64-bit ubuntu.Please send me link to get IDE for 32 bit ubuntu.
Sincerely,
Akshay.
14,995件の閲覧回数
ZhangJennie
Unfortunately, for KDS for Linux, it only supports 64bit system.
There is no KDS version for 32bit ubuntu yet.
Jennie Zhang
14,995件の閲覧回数
akshaybhavsar
I have installed it in windows.It worked for me.But i want to install it for ubuntu too.It generates tar.gz file.Dont know how to install this file.
Sincerely,
Akshay.
14,995件の閲覧回数
ZhangJennie
you don't need install chip sdk (for example SDK_2.2_FRDM-K64F) to your KDS as a patch. you just need discompress it to your local disk. then follow Getting Started with MCUXpresso SDK.pdf (under your chip sdk folder ) , chapter 5 Run a demo using Kinetis Design Studio IDE to work with it.
Jennie Zhang
14,995件の閲覧回数
akshaybhavsar
It generates .tar.gz file.Kinetis IDE accept only .zip file
14,989件の閲覧回数
ZhangJennie
Please make sure you select Host OS as windows.
It's possible to get .tar.gz if you seclect Host OS as Linux.
see attached video.
Jennie Zhang
14,989件の閲覧回数
akshaybhavsar
If we make new project there is option for selecting SDK.but how to select SDK for exhisting project.
14,989件の閲覧回数
akshaybhavsar
I have installed kinetis IDE.I have opened project successfully.I need to install SDK.Which SDK i need to install for MK64FN1MOVLL12 controller?
14,988件の閲覧回数
ZhangJennie
Please go to this url then follow the video to download SDK2.2.
Welcome to MCUXpresso | MCUXpresso Config Tools
please note:
1. select the correct configuration for your target
2. make sure the sdk you download is built for KDS.
Jennie Zhang
14,988件の閲覧回数
ZhangJennie
the "project ->open project" feature works for a closed project inside "project explorer".
If you want to import another project into KDS IDE, use "File->import".
See attached video for what I am talking above. Hope this helps.
Jennie Zhang
