Keyboard interrupts
Keyboard interrupts
1,644 次查看
davidsherman
Senior Contributor I
I have created a GPIO component, and I have MQX-Lite running.  I can use the GPIO APIs to set and clear the outputs.  Now, if I try to enable events on a pin, it just says they aren't supported, yet the pins have keyboard interrupts attached to them.  If I try to use the IRQ module, it only recognizes the port I pins.  Is there a preferred way of using keyboard interrupts with MQX-Lite?
1,499 次查看
davidsherman
Never mind, I wrote my own interrupt handler.
