KE06Z128 trim value location
1,285件の閲覧回数
davidsherman
Senior Contributor I
The KE06 reference manual does not indicate where the location for the factory slow trim values are stored.  From indications in the PEMicro arp programming file it appears the slow trim values for the ICS_C3 and ICS_C4_SCFTRIM are in 0x3FF and 0x3FE, however, I read 0xFF in both locations.  The KE06 in use boots up with 0x58 and 0 for the slow trim and fine trim value running from flash.  We are having problems with the debugger programming the correct trim value and need to know how to read the stored trim values.
1,156件の閲覧回数
Carlos_Mendoza
Hi David,
Please take a look at the below thread in which my colleague Kerry explains how to trim the MCU:
https://community.nxp.com/thread/454662
Hope it helps!
Carlos Mendoza
Technical Support Engineer
