KDS3.0 Export
KDS3.0 Export
1,545 次查看
shauldorf
Contributor V
Using KDS3.0 Export project generates large archive file.
What must be included in the Filter Types to reduce size but to be able to import it on other PC?
Shaul
1,326 次查看
shauldorf
Contributor V
Hello Erich
As usual it was helpful
Shaul
1,326 次查看
BlackNight
The same rules apply as for using a version control system (see KDS and Version Control ). Basically you do not need to expert the generated files.
So the 'Debug' folder you do not need for sure.
I hope this helps,
Erich
