KDS  - Keil MDK-ARM integration
2,221 次查看
stank
The latest version 3.0.0 of KDS theoretically supports
project’s export to Keil MDK-ARM.
Even when choosing during the project creation - "Target
compiler as Keil ARM C/C++ Compiler", there is no any .uvprojx
file created, which could be then used for the μVision.
There is some explanation available how to
use Keil with Processor Expert:
http://mcuoneclipse.com/2014/11/09/using-keil-%CE%BCvision-5-with-processor-expert/
but I would like to use KDS instead.
Do you know any proper way how to link my KDS
project with Keil MDK-ARM?
Stan
1,731 次查看
Carlos_Mendoza
Hi Stanislaw,
I think that the following post created by our colleague Erich Styger might be helpful for you, it explains how to use KDS with Keil IDE:
Tutorial: Using Kinetis Design Studio V3.0.0 with IAR and Keil IDE’s | MCU on Eclipse
Hope it helps!
Carlos Mendoza
Technical Support Engineer
