interfacing BT HC-05 using Processor expert component "Bluetooth_EGBT" for KDS 3.0
1,339件の閲覧回数
bheemarao
I am trying to use the PE component “Bluetooth_EGBT” to interface the Bluetooth module HC-05 with freedom board KL43Z using KDS 3.0.0 KSDK1.3.
But the component “Bluetooth_EGBT” uses “Serial” component which is not supported by the KL43Z controller. Is there any other way to use the Bluetooth component for KL43Z
0 返答(返信)
