How to generate srec s3 file ?
Pawelq86
Does KDS requires additional tools to generate srec s3 format of output file ?
BlackNight
Hi Pawel,
'only S3' S19 files is probably not what you want and need. You can generate different formats of files (intel hex, binary, srec/S-Record/S19 files).
See section "Creating Binary Files with GNU ARM Eclipse Plugins" in http://mcuoneclipse.com/2014/04/20/binary-files-for-the-mbed-bootloader-with-eclipse-and-gnu-arm-ecl....
Erich
BlackNight
Hi Pawel,
Erich
