Flash algorithm could not execute completely - k61 chip
1,952 次查看
abiabi
I am working on MK61FN1M0VMJ15 chip. I was trying to access internal flash memory using Flash_SetByteFlash API. With this change, when I try to erase the existing firmware using  flash.reprogram.all /erase, I am getting the error "Flash algorithm could not execute completely". Not sure if something got messed from this memory.
Can someone let me know how to recover from this error?
#kinetisk60#firmware update#firmware
1,717 次查看
jorge_a_vazquez
Hi Abi Abi
This is a brief description about your issue, I'm not sure what's wrong, so could you explain a little more your problem. How did you set this "Flash_SetByteFlash API" that you mentioned?
Accesses to flash memory should be done from RAM. If the FLASH memory is made up of multiple banks it is possible to run code from one bank while programming the other, but as you want to erase all the memory, then you need to make this access from ram
Jorge Alcala
