FRDM-KL27Z on a Windows10 machine
1,482件の閲覧回数
radunasui
Greetings!
I am trying to get my RFDM-kl27z board up and running on a Windows 10 PC. Although I had to install the drivers manually, I still don't see the associated COM port in the Device Manager panel. As far as I've seen, I am using a late bootloader version, V1.12 so it should be fine.
Any help with this?
1,379件の閲覧回数
ZhangJennie
P&E has released a patch for Windows 10 here: http://www.pemicro.com/downloads/download_file.cfm?download_id=460
can this help you?
Jennie Zhang
1,380件の閲覧回数
ZhangJennie
can this help you?
Jennie Zhang
