Error while generating PE Code for USB_DEVICE_STACK (KDS 1.01   KL25Z)
2,396 次查看
sandeeprw
I am using KL25Z and want to develop a new USB Device application.
I have created new KDS project and added Freescale USB_DEVICE_STACK (PE Component).
While generating code for PE components, it is giving following error. (I tried with verison 4.0.3 as well as version 4.1.1 of USB Stack)
DescriptionResourcePathLocationType
Generator: FAILURE: at line 3920: Duplicated %EMBED_CODE identification (file: Drivers\sw\USB_DEVICE_STACK.drv)USB_Test_Deviceusb_deviceProcessor Expert Problem
Generator: FAILURE: at line 3953: %EMBED_END without %EMBED_CODE (file: Drivers\sw\USB_DEVICE_STACK.drv)USB_Test_Deviceusb_deviceProcessor Expert Problem
How to fix this issue?
2,179 次查看
BlackNight
Hi Sandeep,
I have now a workaround (attached). You need to update/replace your existing USB_DEVICE_STACK.drv with the attached one.
The file is located here:
C:\ProgramData\Processor Expert\PEXDRV_PE5_3\Drivers\sw\USB_DEVICE_STACK.drv
I hope this helps.
2,180 次查看
BlackNight
Hi Sandeep,
I hope this helps.
2,179 次查看
BlackNight
I can reproduce the issue, and I have filed a ticket (CR:ENGR00318012). But I do not have a workaround (yet).
Erich
