Error while Debugging the example code for FRDM-K82F
1,278 次查看
mohammadgouse
I am testing the FRDM-K82F kit with sample codes, i am getting error while i am debugging it, screenshot of the output as follows
Need solution for this, I am using GDB SEGGER Jlink connected through USB.
1,220 次查看
ZhangJennie
hi,
I suggest you try if latest P&E or Segger FRDM-K82F board firmware can work for you:
Latest firmware application
FRDM-K82F use OpenSDA v2.1 interface, so you can refer this document to check connection configuration.
to separate the issue with specific project, I suggest you create a new project with wizard, check if the download working normally with this new created project?
Jennie Zhang
