Error in final launch sequence
2,029件の閲覧回数
wendylau
Hi, guys.
I have recently fresh user in KDS 3.2. When I wanna debug my first C++ application, It show Error in gdb version.
And then I install tdm-gcc. And add gdb to path.
Right now, I have encounter this:
Error in final launch sequence. Please help me with this problem. It have cost me whole day to deal with it.
Really thanks!
3 返答(返信)
1,912件の閲覧回数
Hello Wendy,
After build , is there error ?
If no, which debugger do you used, please show the debugger configuration of KDS .
Alice
1,912件の閲覧回数
wendylau
If I use the defaut setting like this:
the error is :
If I change the debugger setting to this:
the error would be:
Really don't know how to do about this.
1,912件の閲覧回数
Hello Wendy,
Please select on of the three to debug refer to which debug mode you used:
MBED, PE or J-link ?
Alice
